Windscreen scuttle advice please
Sorry all this is a bit of a long one - but life with a G is a bit of a never eneding story!!
I have had a significant amount of work done on my 85 300GD (many thanks for all teh advice greatfully recieved so far). Since a significant amount of body work and a full respray all done very well and to a high standard (not just my opinion - honestly) one area has remained a problem.
Despite having no previous rust on the panel, rust has developed along the joint seam under the windscreen. One attept to correct this has resulted in teh problem returing within 6 months. I was picking up a steering box from our frends at Malvern, and he commented that this was not an unusal problem on G's subjected to a lot of body work. Following his advice we drilled into teh scutlle from inside and drew a hot waxoil injector along it.
Whilst doing this a very limited visual inspection failed to see (endoscopic camera) any significant internal rust in this area (I assume this would not be the same area that the spindle go thorugh though as it has definately had wet carpet syndrome - cured ongoing with now 2 new sets of wiper spindles and parking down hill where possible!!
So where I am at is a choice. I want to get rid of the rust before we go trhough winter and have costed a proper screen out/ sand blast the rust out and seal the seam with correct flexible joint filler (to current merc authorised body shop standards (it looks like half the seem has no joint filler in it! currently). That's about £450.
Or to cut the offending panels off and replace with new as teh concern is (expressed by the body shop not me) is that the problem will just keep repeating. no my recollection is that whilst the outer panel aree relatively cheap £60-£90 each?? I am assuming if teh rust is that bad then the internal one will need doing and that one if north of £500 so we are looking at a potential £2k fix!!
So advice please. The original panel is solid - I know becuase I have worked on it and when it went if for teh second time and got acid stripped they confirmed only slight new surface rust. the windscreen revela is rust free, so that leaves potentially the area that the wiper spindles allow water ingress into, but there is no eveindence under the dash of rust or rust staining.
The waxoil will stop the water from leacing from the inside out, and flexible filler should stop it from the outside in, so even if the seam is rusting no water or oxygen means no more rust??
So put simply what would those with more experience do - believe me if I need to spend the dosh now and get it right I will, but I am not sure a full rip out and replace it is needed?
Thoughts??
Many thanks
Simon
I think you have answered your own question, there is only the two options, spot blast and epoxy prime, or replace the panel.
My G-wagen is just about the same and has the original paint on it, I have been doing some paintwork here and there as there were much worse areas. The screen surround was the least of my worries!
If it was my decision I would be cleaning the corrosion with spot blaster and MBX tool, epoxy prime the panel, then seal and painting over the top of that. I would be taking the window out as stated and cleaning up all the flange where the seal is, mines looks abit rusty inside as well. This could last for ever, or it could last a couple of years! but it would be my option as the other option f panel replacement would be scary, my old G needed that work carried out, so I sold it, to much for me to get involved in, financially and emotionally!
What I would be questioning is why has it rusted if it wasnt before! MB state when metal is exposed from the bodyshell you must prime it within 40 minutes or surface corrosion will set in. Or there maybe acid in the seam that has opened up the paint abit!
This is most likely due to windscreen seal failing, and thus corroding metal behind seal, unfortuately windscreen removal is the only way to check condition, though it may be a nasty sight there? Shouldn't cost that much for someone to remove screen they should be able to reuse old seal, if all ok?
Just make sure they use a spot blaster and mbx tool to clean it up and not a sander, sanding leaves the pitting in by only flatening over top of it, where as spot blasting and mbx hit the rust from above thus cleaning right into the pitted area.
Epoxy primer is the best, Mercedes research centre in Germany during the late unpleasantness with the 210 e-class carried out research into every product they could find in the marketplace to remedy the corrosion problems they were having and found that spot blasting and epoxy priming would last longer than anything else!
Epoxy primer can be sprayed direct onto the metal as it is an acid etch as well. If there is any pitting that needs body filled, it should be applied over the epoxy primer as this is the approved method. Not the "workshop" know how of fillering direct to metal as it will hold it back longer, thats hearsay! make sure they get epoxy on the metal no longer than 40 minutes after it is stripped out, i.e. not lying overnight in the paintshop waiting for someone to start it in the morning!!
Painters hate epoxy primer as its not easy to rub down, they are crafty at using two pack instead of epoxy as its an easier rub!! but thats not in your interest!
I hope this information helps, I have delt with rusty Mercs for the past decade and this is how we have delt with them!!
Rusty Mercs, not seen any of them......hahahahahaha ;)
LOL Gav, I think we have all tried to block them out of our memory, in fairness we are not getting any these days, 211 eclass onwards seems to be sorted!!
Oh, I also remebered, there was agreta post on here from Fixwin about how to deal with cleaning up and treating the windscreen seal for longevity and sealing purposes when putting it back in, it would be well worth finding out that info as well. Dont let them cut it out, my old G had a full missing front screen panel ecause autoglass had cut the seal/paintwork!
If it is acid dip still in there is can be neutralised with paint thinners so a good scrub out when exposed metal is there would be a good idea!!
We are doing a stack of SL just now, we have had 4 in the past few months and one was a full restoration! we have just completed two older 1960 se as well. I think those SL would be a good investment if you had somewhere to store one!!
Well thats good and bad news,
Is it coming in the seam at the screen where the inner and outer are spot welded together and running down into this. Or coming from a seam up where the screen panel to roof joins?
I really hope this elimates this as you have done some amount of work to this G, it would be terrible to see this wee bit being a constant nuisance!
I worst came to the worst could that full seam not be cut out and replaced with flat plate, therein removing the problem full stop? replacing those panels would be really invasive and expensive!
I have my wiper spindles etc just arrived, I plan to put them in the next couple of weeks, I ordered it as I have a water ingress in my passenger side footwell. The battery tray was the cause of most of it, but that got welded up and is sound and there is still a wee dribble coming in, so the spindle is next! here is hoping that solves it! as i have my fuse box ripped out to stay out of the way of the water.
I'll finish my oil servicing tomorrow and give the full underside a clean up, stonechip and wax coating, wirebrushing is fun!!
Just re-reading these posts, the soft putty like sealer taken from under the paint maybe key to finding the actual fault!
That is really strange that its soft! I wonder if it wasnt cured out right before overpainting! I wonder if it was a waterbased sealer!
The ones we had were ok, we have put a bulkhead in a 107 before it was a bit of a guddle as there was nothing to weld it to lol.
It sounds like these guys really know what they are doing which is peace of mind, your only issue is of course water coming from the other side of the seam under the sealer, I would get that waxed to death, especially after being in the oven, it tends to run abit with the heat!
I wouldnt think that skin wouldnt be structural, its probably the way they were designed to be assembled in sections which means that it could be plated. I would like to see a few pics of your G as it sounds like you have done loads to it!
well done nice looking truck you've got there
That does look fantastic! and a pile of work has went into it for sure, there is not many cars get that much of an overhaul! So what do you use it for, do you ever get it dirty??
I want to find some side steps for mine at some point in time! where did you get them from?
Hi to both of you.
You have reinforced where I am at on this. Given the panel was not rusting before and having had the windscreen out myself I know the flange is ok as well, I think it is time for a repaint only option with as you say a lot of well informed chat about epoxy primers etc. so they step up to the mark.
I do think the fact they acid stripped it is, as you say, a big clue to why it has gone wrong. One bit of good news though, as the screen is coming out, I can put my new rear view mirror in :-))
Thanks again
Simon
Ps it's going to a different body shop for this attempt though!
