Window Seals (Front) GES300
These are $42 a pop from the fourbyfourclub site. Does anyone know (that means you Mr Helme...
) if they are cheaper here?
More importantly, are they a pita to fit?
Just got my Jallop back and now have the benefit working brakes (braided hoses) I can have lots of fun!
Thanks folks.
Ian
Hi Ian
Glad you got it back on the road
it just needs a turbo job now ![]()
Front Door Window Outer Scraper Seals A463 725 04 65 £20.80 EACH +VAT NOT HANDED
Front Door Window Inner Seals A463 725 03 65 £26.00 EACH +VAT NOT HANDED
MBUK have the outers in stock and are common and easy ish to fit IMHO
MB Germany have the inners, not so common and easy ish to fit IMHO
Give me a call if you want them
What about Sunroof seal? Are these hard to fit?
Hi Jason
Hows you?
Which seal, there are about 6 main seals on the roof and frame, they are nearly all PITA
Will send pictures if you need
Hi Ian
You have a PM
I can agree to those terms but if the are easy (ish) do i get LUI 9314 for free as nobody wants it? ![]()
Just fitted a couple of window scrapers (thanks Gav).
Take great care removing the old ones as the spring clips that hold them in may be corroded.If broken they would be very difficult to replace. I soaked them in WD40 first - 6 per window i think - and then prized them open with a small sharp ended screwdriver and eased the old one out a clip at a time.
Refitting is great fun but once you have done one the second is easy.
Let us know how you get on.
PS Mr Helm is much cheaper than £42 or even $42 ($1.54 to £1)
Hi Gav,
Not bad thanks, unsure no leaks here, just wind noise but may be they all like that, maybe I might try tape on the front to see if it any better?
Hi Guys
Just in case you drop / lose / break a clip or two
They are available from MBUK
They have 58 in stock and they are £0.30 each
Part number A381 988 00 78 - 6 per door / seal
There are a few dealers around the country with stock also.
Done
For £4 it don't seem worth worrying about!
Hi Gav...Many thanks, yes I think I'll go with all four ie two inners and two outers. I will of course require a full refund plus 35% shoud they prove difficult to fit!!!
I'm flip flopping on the TT. Seems I don't need the con-rods adjusting....Hmm
