Rubber Side Trim Clips/fixings for 460
3 replies [Last post]
ajpclements
ajpclements's picture
Mid way through a 460 respray/rebuild
Does anyone know where to get replacement fixings to reattach the rubber side protector strips?
A lot of mine cracked when removing the strips for respray.
Any suggestions gratefully received!!
Re: Rubber Side Trim Clips/fixings for 460
From dealers  largely, possible part number for clip or lock is A 460 994 01 45, please double check with your dealer, you will need chassis number. There is some 68 in number of these and screws to go with it.
If you have a sample similar clips could be sourced from workshop consumables suppliers like Wurth.
Nice colour scheme :)
Part number is A460 994 01 45 and there should be 58 on a SWB, 64 on a LWB
They are £0.50 each and MBUK have 576 in stock
Not sure where you are in the country but quite a few dealers have stock also, like Rygor (Mudie Bond) at Tewkesbury with 102 in stock.
Hope this helps
ajpclements
Huge thanks guys, will call into MB today.
I have tried before but without the part number they were not too helpful.
will keep you posted
