Removing Grill Badge from W460
Sun, 03/03/2013 - 12:58
How do you remove the Grill badge from a W460??
Do you need to take the grill off to unbolt it, or can it be unscrewed from the front??
Thanks in advance.
Sun, 03/03/2013 - 13:04
Re: Removing Grill Badge from W460
there is a small nut behind grill off
Mon, 04/03/2013 - 19:50
#3
be careful with the bottom rubber mounts
if you only remove the screws from the top of the grill and reach your hand in you may be able to undo the star holding nut
if you are too heavy handed you will separate the metal from the rubber and will require new mounts ( or cable ties )
Tue, 05/03/2013 - 20:37
#5
The end of the bolt / stud should have a flat screwdriver slot in it so that you can hold it, s stubby driver should be OK, however if it is spinning in the plastic star then it may just break out anyway
Thanks Adrian,
I will unscrew the grill and give it a go.
