my little G
2 replies [Last post]
firebolt
firebolt's picture
well, been 5 days to be a happy G owner...
so far,
-fixed the leaking wipers
-surface rust cleanup and preservation floor panels
-mounted radio :-)
-replaced all the door window lower seals ( don't know if that is the correct name ) they where all corroded, and leaking
-fixed the electrical wiring driver door W463 mirror , working again, ( wires shot in the hinge )
- fixed the power windows, driver side ( same problem as above )
-new fluid reservoir cap , clutch & diff
-pin pointed the central lock problem, ordered a complete new set actuators and motors,
cleaned, greased all the locks, and make new water barrier foil in all doors
-replaced the left door outer handle ( mounting screws corroded , and the brass inserts spinning in the plastic )
-hang out to dry the front floor mats,
-tried to adjust the free play on the steeringbox... did not help,  ordered a refurbished one ( need to order a new filter and oil for the pump so i can flush it and change the filter )
-mounted new D pilor vent scoops with the foam barrier ( to prevend direct watter intake ) they where missing
-tough up paint all the stone chip places
to do, prio things first,
change steering box,
aline the front wheels , check front suspention, front bearings ect
fix leaking rear crank seal ? still have to check this , but 10 to 1 it's the rear crankseal
balance wheels,
change all fuilds and grease,
springs change/ determin problem  ( car is hanging a little to the left )
HID aftermarket H4 kit placement ( see if there is space )
clean up rusty spots and preserve these
change front window and seal , and check window frame for rust ( clean up / repair )
fix towing hook wiring
make led light interieur cargo aria
blind rear windows
make front bumper / bull bar
16" wheels and little bigger tyres ( narrower )
rear door replacement ? or fix
new left front side trim ( little crack )
seats intereur  upholstery , custom made / new covers ?
i have a new hobby :-)
and i like it
Re: my little G
Been a busy little bee then wink > Pictures?
firebolt
firebolt's picture
Re: my little G
steering box
needed some strong languish to get the link arm off
cleaned up the connectors
hoping to morrow morning the local Merc dealer will have the grease whipes for the king pin balls
so i can go ahead with changing the wheel bearings and king pin bearings
i don't want to take this off two times
