I need a couple of part numbers
Morning...
I need a couple of part numbers please
A front hub grease cap
The small hose from the clutch resevoir to the master cylinder
The plastic clips that the side rubber mouldings screw into ( on the front/ rear wings , doors and side panels)
The grommet that goes around the fuel tank filler neck
And finally a nut for an engine mount...how the hell did i misplace that.....??
many thanks
Steve
Hi Steve
PM me your chassis number and i will sort for you
If you don't have it to hand is it a 460 or a 463 and what model should do...
Having re read this i am assuming its a 460 chassis but here are the basics, i need the chassis number for the clutch pipe no matter what it is....
W460
A front hub grease cap A108 334 00 25 £3.95 + vat MBUK have stock
The small hose from the clutch reservoir to the master cylinder NEED CHASSIS NUMBER
The plastic clips that the side rubber molding’s screw into ( on the front/ rear wings , doors and side panels) A460 994 01 45 £0.30ea + vat MBUK have stock (64 fitted)
The grommet that goes around the fuel tank filler neck A460 471 00 79 £4.80 + vat MBUK have stock
And finally a nut for an engine mount N910113 012002 £0.90ea + vat MBUK have stock
W463
A front hub grease cap SAME AS W460
The plastic clips that the side rubber molding’s screw into ( on the front/ rear wings , doors and side panels) SAME AS W460
The grommet that goes around the fuel tank filler neck A123 997 35 81 £1.95 + vat MBUK have stock
And finally a nut for an engine mount SAME AS W460
Hope this helps
