hub caps???
anyone ever come accross nice 16 inch hubcaps for steels??
Try these sites,
https://www.suburbanwheelcover.com/
or
type: "16" wheel covers" in the url window; there is a host of suppliers there.
Not sure if this will help or not!!!!
All the 202 (1993-2000) 203 (2000-2006) 204(2007 on) chassis C Class's that had steel wheel option fitted have 16" wheel trims.
The issue is that most had alloy wheels fitted from the factory so they can be rare ish.
The older 202 chassis will be most common, then 203 and you may struggle to find a UK 204 with steels.
However still NOT SURE IF THEY FIT OR NOT!!!
I have seen a MB PC wheel trim fitted to a G and i also know they can fit the sprinter van wheels.
The 906 chassis (2006 on) and 639 chassis Vito (2003 on) also run a 16" steel wheel option with full sized wheel trim
Again NOT SURE IF THEY FIT OR NOT!!!
Hope this helps
Where are you in the country? If you are in Yorkshire / Humberside i will have a Van trim you could try...
very fancy lookin, just puttin the topic out there for anyoue wantin a cheap pimp... oh yeah i'm in tipperary and as you all well know thats a little too far away, especially at 65mph max..... ;-)
