Front Stub Axle and Hub Assembly
Looking for replacement stub axle and hub assebly for 463 LWB G320, new parts extreme in price, any suggestions appreciated
Diagram attached
What side?
What's wrong with the original?
Any photos of the original?
Perhaps that place in Albania?
http://www.gwagenalbania.com/ListParts.htm
Checking the part numbers of stub or swivel housing against your chassis number and comparing the same part number of a G300; they are the same.
Therefore, a stub of a UK spec G-Wagen (W463) should fit your model. By Mercedes-Benz's standard 'RIGHT' is when viewing from the rear of the vehicle; I think, when you mentioned 'Right', it was viewing from the front of vehicle.
Try James Lafferty at:
G-Wagen International.
Tel: 0118 972 1100.
Alternately, try him on his email:
sales@g-wagen.co.uk
URL:
www.g-wagen.co.uk
It would be prudent to ask James of the axle number he may propose to have the part removed from and check with your dealer against your chassis number and axle number if the part is of the same number, before removal.
I have a couple of 463 front axle CV's and some drive shafts.
No hub.
Right side and stub axle completely disintegrated quite a shock, wheel staying on by just the brake calliper
