on e-bay
18 replies [Last post]
http://www.ebay.co.uk/itm/MERCEDES-300-GD-G-WAGON-GREEN-/180943514182?pt...
bit of an oddball car, looks like a 617 diesel to me and age wise I say early 80's
fixwin38
fixwin38's picture
Re: on e-bay
two batteries and round voltmeter so 24 volt ... looks to be a 617 engine... old style steering wheel ...dash with rocker switchers  so 80/82 on the year ....Mtex interior. rubber floor covering might have an interesting history???
tony.bruegger
tony.bruegger's picture
Re: on e-bay
Have asked seller for vin no.
Militare build
v = rpm
small km....nice
mark
mark's picture
Re: on e-bay
 What, in the red at 2900rpm ?
peter perfect
peter perfect's picture
Re: on e-bay
 Volt meter .? It's a rev counter ! Also what's the yellow indicator to the right of the front diff lock light and above hazard indicator? Unusual, a fan of some sort, there's not much on it to indicate military spec accessories!  Although an unusual plug on wing just in front of brake master cylinder.
Re: on e-bay
The unusual symbol warning light is called Combustion Controller on the EPC and it only lists as fitted to W461 chassis types. The only 2400mm short wheel base model i can find with it fitted is a mid 90's 290GD in German Army spec. Chassis number would tell all....The vendor says its a 290GD which would make it a OM602 but clearly its a OM617 fitted and badged as a 300GD? Interesting. It looks like it may be to do with an additional heater? Not sure...
The bracket and Plug on the Left hand inner wing is i believe a Jump Start Plug Socket in military spec.
tony.bruegger
Re: on e-bay
It is WDB46033217043601 for you all to look up
Re: on e-bay
That chassis number although a W460 300GD SWB baumuster and is LHD steering.
The serial number does not exist  to a WDB 460 332 17 type on German EPC or VeDoc systems
Either its wrong or just a bit suspect?
Re: on e-bay
It's actually WDB 460 332 17 045601 and it is a LHD 1985 300GD SWB in 6870 Nickel Green and 24v and was sold to Denmark.
Fitted with…..
617.932 24volt OM617 5cyl NA Engine
711.202 G1/17-4/4,628 4 speed Manual Gearbox
765.502 LS2B Power Steering Box
460.533 2400mm SWB Body
730.300 AL0/1 C-1,3 Front Axle
741.502 HL0/5 -1,8 Rear Axle
750.609 VG 080 Transfer Case
With optional extras…..
C27 REINFORCED FRONT SPRINGS STAGE 1
C79 CHASSIS PARTS MODEL BOUND
E51 SHORT RANGE INTERFERENCE SUPRESSION
F79 CAB PARTS MODEL RELATED
G75 SPEEDOMETER ADAPTER
L30 PROTECTIVE GRILLE FOR HEADLAMPS
P48 REAR MUDFLAPS
S18 SEAT INCLINATION ADJUSTMENT FOR DRIVERS SEAT
S71 1 SEAT LENGTHWISE SEAT BENCH RIGHT
S72 1 SEAT LENGTHWISE SEAT BENCH LEFT
V29 INTERIOR TRIM IN GREY
W73 ROCKER PANEL ON REAR PANEL DOOR
Z98 BILL OF MATERIALS ORDERED
Z99 ORDER AS PER DETAILED DESCRIPTION
The symbol in question is an additional heater that appears to be controlled from some additional switches in the centre of the dash. It also has Front and Rear Diff Locks, Brakes with Fording Abilities, and one piece Rear Bumper.
Looks like a good project for somebody……….
fixwin38
fixwin38's picture
Re: on e-bay
If you look at pic of engine bay there appears to be an electrical connector  with a screw cap close to where the jack would be stowed and at the far side front additional equipment attached to the coolant  circulation system could that be a mains electric night heater for the coolant.!!?? .bearing in mind it was built for Denmark as a Military use vehicle ordered from Graz by the Danish Mercedes main dealer ....
tony.bruegger
Re: on e-bay
Am a bidder on this one..dont want to run it up ...plenty of rust....could do with a lhd chassis +V5....wd sell engine/box sensible £ to member pm me or 07802846761 TB
tony.bruegger
Re: on e-bay
This interesting lhd militar danish issue 460 is now on its way to my yard.
YUK ! 580 mile round trip
It runs v. sweet.
Will be on show during Axels' open weekends [qv]
hus55
Re: on e-bay
lucky you tony !  whats the plans with this one ?
it looks like axels open weekend is going to be like a AGM.
rgds hus
tony.bruegger
Re: on e-bay
WOW ,
Will start new thread with 60 picassa pics
LUCKY ' Barn find ' 100% original
Could some one post battery size possibilities plse ?
Get mot ,tidy up  ,go to KENT military show next year ,SHOW off
Re: on e-bay
MB List twin 12v 88ah or 12v 90ah
Retail £103.00 ea + vat should easily get a pair from MB for less than £200 all in with a 2 year warranty.
They are however nothing special
I will try on Monday to get you some physical measurements for them as i am sure we carry them for Vario van range and they are very similar to the Vito albiet only singular.
tony.bruegger
Re: on e-bay
Quite small...can you get a battery code or dim ? THX
Re: on e-bay
Basic supercession list of MB battery part numbers to this application....
Part Number       Description
A0045411301  BATTERY 88 AH
A0045413101  BATTERY 88 AH
A0045411501  BATTERY 88 AH
A0045413001  BATTERY 88 AH
A0009823808  BATTERY 90 AH
Previous price is for the last number on this list....
Rough Dimensions over the phone from my night shift guy and a ruler !!!!
345mm Length  x 175mm Width x 170mm Hieght
12V 90AH 760CCA
12 Volt
90 Ampere Hours
760 Cold Cranking Amperes
MB don't refer to batteries by a generic code i.e. 037 or 063 etc
Basic fitment is for a 814 Vario if you want to look for an aftermarket product
Hope this helps
fixwin38
fixwin38's picture
Re: on e-bay
Hi Gav
this is a 24v military system so two 12v batteries in series BUT they must fit the tray..I see in the pics two battery clamps so best idea would be to approach a battery supplier  and measure the dims / post locations to fit within the profile of the tray and the clamps. they look about the size of 50/55amp which would give about the same output as the standard  T6 military 12volt ( big square one)
Re: on e-bay
Hi Tony
The listings i have given you are for the twin 12v in series type batteries the same as fitted on a Vario which most are 24v.
That is the exact same part number battery that is listed for your G the only difference is the batteries when fitted to a Vario are
just side by side in a purpose built tray. In the G they are i think in an L format to try to fit in the G's existing tray as per pics on EPC
Hope that makes sense
