drivers door central locking solinoid
5 replies [Last post]
stevo
stevo's picture
Hi all has anybody got a drivers door central locking solinoid for a 3dr w460 1988 please ?
Re: drivers door central locking solinoid
Would about £54 be a clincher?
I have two numbers but I am not sure which door the numbers are for, due to a catalog error.
A003 820 32 42    ELECTRIC MOTOR,Left front door
A003 820 49 10    ELECTRIC MOTOR,Left front door. Check the supplier's URL.
http://www.starpartz.co.uk/products.html?productID=2700
Alternatively, check with
http://www.spalautomotive.co.uk/
and ask if their after market solenoids will directly replace an original part? You will have to check how many leads the solenoid has.
stevo
stevo's picture
Many thanks i appreciate your help rgds stevo
mgrays
mgrays's picture
Never seen an aftermarket one that is a direct replacement  as the shapes are different. No doubt you could make up brackets but the OEM installation is neat if a pain to remove (the solenoid is right up inside the rear pillar of the door so you need to remove door handle, door lock to even have a chance.. and really the winder mechanism too.
The system on a 1988 460 is odd.. it has one switchable master at the drivers door and the rest are looped in a diasy chain slaves with switches to pass the message/signal onto the next slave as as opposed to the normal master/slave setup.
For parts from my notes;
http://www.mb4x4.co.za/forum/content.php/54-W460-230GE-Gelandewagen-Central-Locking-Repaired
A003 820 3242 = Slave/passenger central locking actuator = 73 Euro
A003 820 4910 = switch/driver central locking actuator = 180 Euro
A 001 545 35 15 ANZEIGELEUCHTE 8,79 € 10,20 € central locking lamp holder on dash
460 series
Right Front (Master) A003 820 49 10 £219 + VAT MB Germany
Left Front (Slave) A003 820 32 42 £89 + VAT MB Germany
Rear Doors (Slave) A003 820 32 42 £89 + VAT MB Germany
Tail Door (Slave) A003 820 33 42 £89 + VAT MB Germany
463 series (early)
Front Doors A004 820 24 42 £79.50 EACH + VAT MBUK
Rear Doors A004 820 25 42 £63.00 EACH + VAT MBUK
Tail Door A004 820 24 42 £79.50 + VAT MB UK
Chassis number to confirm part numbers and if factory supplied..
Hope this helps
stevo
stevo's picture
Gav , as usual you always come up Trumps ! Cheers stevo
