Can some one help with a part number please ???
Greetings one and all dose some one know or can some one find a part number for this switch??.
This one will have to be for Gavin to reply, the Russian EPC site is down at the moment.
I expect this would be off a W461 for I know not of any W460 or W463 to have had one.
The Switch itself is generic (it is the same as the Heated Rear Window Switch) but the switch insert is (I think)
A008 545 0190 and should be fairly cheap.
Eurotruck in the US sells them for $3.20 each but it would probably cheaper to but in the UK (sans postage).
I hope that this helps
John
John is bang on...
The Switch is A003 545 26 07 (£37.20+vat MBUK) and is indeed the same as the..
Rear Interior Lamp
Heated Rear Window
Ventilation Flap (Recirculating Air)
ABS
As fitted to most 463 G's
The little square symbol that represents the Winch is A008 545 01 90 (£1.85+vat MB Germany) and it just pops into a recess on the switch front
All MB switches have the number on the side or bottom if you need to swop / check / try one
Thank you very much..
