Bloody marvelous
Well done to whoever turbo charged, or cleaned the injectors or whatever you did to make everything work in reall time.
Thanks for the hard work.
Agreed....it's certainly wizzing along
Sharper in appearance and so much faster ...
Thank you.
It is much faster, but I get through less coffee, not having to wait for things to load
And it doesn't seem to kick me out when I click 'save'
Finally someone has put a V8 5ltr+ Engine on this forum! Whoooooo!
spider if what your saying is true i wont be logging on too often because the electricity bill to fuel this forum will be horrific !!!!!!!!!!!!!!!
[if it stays like this i will be here more often. my onyl pee'd off concern is that i cannot post photos here which happily post on facebook and clubwagen !] if this issue is solved i'm sorted !]
Hus,
Great insructions by Audiominx on how to put pictures up. It's easy, just get some pictures up.
Here is how to do it:
Or at least how I did it.
Got to HOME on the left hand side, then CREATE CONTENT, then CREATE GALLERY
Name your gallery
Add any text you want to explain etc
Save
Click on the gallery you have just created and then UPLOAD IMAGES
Do this as you would adding pictures to anything else.
I managed and if I can, anyone can!!
Good luck
Hopefully you should see a choose file box under box where you enter text.
May say "Browse" on a PC
...but how to put them in a post? all I can do is put a clickable thumbnail to a hosting site.
