Adjuster rear 460 280 87
Sun, 29/01/2012 - 16:08
Help needed...
Trying to locate a rear brake adjuster for a 87 460 G280 to get though MOT
Got two new rear cylinders for £14 each and a master for £150
from www.brakesint.co.uk/
THX
Sun, 29/01/2012 - 18:10
Re: Adjuster rear 460 280 87
The adjuster you are after is a dealer part only.
I am surprised that you require one or two; these can be stripped down, cleaned, greased and re-used, why do you need one?
As far as I am aware there are two types of adjusters so your axle number and other vehicle details are vital to locate the correct one.
Mon, 30/01/2012 - 17:12
#2
If you PM me your chassis number i will try to work out the number and give you any alternatives i can find
