300 Going through dizzy caps???
23 replies [Last post]
lenny
lenny's picture
Can some one help / shead some light on, why my 300 is going through dizzy caps and roter arms once a year..??? I would not mined if I did lots of miles a year but I only do around 6 to 8k a year...
I am replacing them each time with as recomened bosh parts.
Re: 300 Going through dizzy caps???
Hello Lenny,
The obvious place to check for me would be the spark plugs heat range and gap. If the gap is bigger than it ought to, your igniton pack is turning up the current to the coil thinking it has a high resistance. The high current could be burning the carbon in the distributor cap. Make sure you are using the correct spark plugs; if you have modified to use multi-core plugs or platinum tipped plugs, make sure they are the correct ones'.
Check the HT lead and connections between the coil and distributor tower, are these pushed in good and proper? Is the lead fine? Then check the rest of the leads, have thes voltage and resistance checked on an oscilloscope. Is the coil the right one for the vehicle?
Are you using Mercedes ignition leads or are these after market? I know M/Benz one are expensive but well worth paying the price for them. These leads come in parts of three per lead. The spark plug end, the lead and the distributor end. These screw on and resistance can be checked as a whole lead and if you get a high reading the parts can be unscrewed and relevant parts replaced as necessary. A word of warning, unscrewing an old lead could snap off an end, in which case a dealer has equipment to either fit a new end or persuade you to buy a new lead.
A long shot, check and clean the base of the ignition module for good earthing. You will need to apply a special paste to the base before re-fitting. I do not know what it is called but you should be able to buy from a dealer.
Do keep us posted.
lenny
lenny's picture
Hi Rakesh,
When it broke down last year when out with the gwoa, I had all the leads replaced with Mercedes ones (you are right they are a lot £££££) also spark plugs as recommended by Mercedes and both cap and arm were bosh. All put in by an old school Mercedes mechanic ( not your modern fitter).
He said some of the 300 engines had this problem.
So I though I would ask the question to see if some one has had the same problem, and got it fixed or had any thoughs on it..
Hello Lenny,
If the leads and spark plugs are fine as you say, do make sure the leads are pushed in the towers at the distributor and coil.
Would you PM me your chassis number and if you can, any numbers from the coil and ignition pack.
I must say, I have never heard of any issues for the distributor prematurely burning out; I will make enquiries.
Have your charging rate checked, I am persuming if the charge rate is high, the coil may be getting high input hence, output a high discharge.
lenny
lenny's picture
I will send then when I get home..
Online
Copy me on the PM Lenny and i will help Rakesh with his research
No luck with selling it yet then!
G-Restorations
G-Restorations's picture
What's a dizzy cap?
Online
Hi Lenny
Here is a list below of the part numbers that apply to your chassis number.
Hopefully you can check that you have the correct set up.
I have only 2 comments from experience…
I have seen on a few occasions damage to the Bracket that the Rotor Arm screws onto, on the end of the Camshaft, bent and or cracked in most cases. Probably through over tightening of the 3 screws that hold the Rotor Arm on, worth just checking on.
Also my view on the Bosch replacements products, and all OE quality suppliers, although the parts are of reasonable quality, I would always be fitting the genuine MB Cap and Rotor if you could afford it. It is easy for me to say this from my sofa in the Yorkshire countryside and I have no possible guarantee that it will cure your truck! But from experience the MB items are of better quality.
This I guess will not stand up in a court and I remember MB getting into hot water with a supplier a few years back for stating that the MB version of the suppliers product was different and better than the one supplied as an aftermarket OE item and that the MB ones had gone through a more stringent quality control and the rejections found their way into the OE parts network. What I can tell you is that MB constantly develops parts and over the years will modify them as issues or problems arise or manufacturing techniques change. When you buy the MB part you always get the latest version. This is not so if you go and buy an OE quality part made by the OE supplier. This could be any one of the earlier versions and may or may not really be up to the job.
Think of it like Microsoft and Windows….
The MB Genuine item will always be the cutting edge Windows 8…
The OE supplier might be supplying Windows 7, XP or 95 or 3.0, you just don’t know!!!
You could buy a new part that has an inherent failure built in that the latest MB item has had it fixed, it will be cheaper for a reason, and there are no real bargains anymore, in effect your buying New Old Stock.
Obviously this will be OK for some parts, but any safety critical items or items that could damage the drivetrain or cause repeated failures and breakdowns, sometimes even causing collateral damage should in my opinion be avoided.
Anyway….enough of the sermon….
Distributor Cap – A103 158 00 02 X1
Rotor Arm – A103 158 03 31 X1
Spark Plug – A003 159 05 03 X6
Suppressor Plug End – A000 156 54 10 X6
Distributor Cap End – A000 159 28 42 X7
Coil Cap End – A000 159 29 42 X1
Brass Crimp Screw End - A000 159 14 38 X14
Plug Lead Cable – A110 159 18 18 X4mtr
No1 – 340mm
No2 – 420mm
No3 – 580mm
No4 – 580mm
No5 – 740mm
No6 – 870mm
Coil Lead Cable – A115 159 08 18 X1mtr
Coil – A000 158 50 03 (Original) – A000 158 62 03 or A000 158 53 03 (Latest)
EZL Unit – A008 545 36 32
Cam Drive Bracket – A103 158 08 40
Cam Drive Dust Cover – A103 158 00 88
Cam Drive Seal – A014 997 58 48
Distributor Cap Cover – A103 158 05 85
lenny
lenny's picture
Thanks for that I will have a look and let you know.
some of us prefer XPcool
Dizzy cap is the trade slang for distributor cap.
....or OSX
G-Restorations
haaaaaaaaaaaaaaaaaaaaaaaaaaa  I knew someone would bite,  Petrol the fuel of satan,
Gordon
IanA2
IanA2's picture
Specifically Mountain Lion smiley
No, No you can't hook me, I am too little - so you will have to throw me back in.crying
Online
Some of us live in the 21st Century wink
Online
Strangly enough all the MB Systems and Platforms run in Europe would only operate on XP upto 2012.
We are now playing with the very advanced Windows 7 crying
lenny
lenny's picture
Sorry Gav I have just read this propley...... I am not selling it now...got the wife a bigger car insted.
lenny
lenny's picture
well i got round to looking into the problem yesterday, and as I though it yas the same problem...........
If you look as the the photo of the roter arm there is some heat damage.....
I would renew the rotor arm, yours is tracking and also clean or replace the yellow disc shield and seal seen in photo 2. JPG. I do not know what the other side of the shield is like and cannot say from the photo if I am looking at tracking marks or dirt.
The distributor cap can be re-used, just clean the carbon from the terminals; lightly scrape using a flat blade screw driver.
Clean and wipe the rotor arm base or shoe, the metal part the rotor is attached to.
If you do have your reciept from where you had bought the rortor from, without cleaning the rotor take it back and claim under warranty, if it is less than months or have done less than 6000 miles with this rotor.
panzer
panzer's picture
Hi Lenny
I have the same engine as your (very nice) 300 ges in my r107 300sl.
It seems to need a new distributor cap and rotor arm every 18 months / 12000 miles to keep it on song - it appears to be a consumable on that engine type. On my 230ges the cap and arm are about 8 years old and other than a clean now and then are fine.
Next time it comes off I will follow Rakesh's advice and clean everthing up.
It is an expense I could do without and would like to know if there is a fix for the problem.
Petrol - fuel of satan? We all know the diciples of belzibub have all the fun!
I had the same problem the year before last when the dizzys in my g-wagen and my w124 both went with in a couple of weeks of each other, I carry spares of them nowcool
Petrol - fuel of satan? We all know the diciples of belzibub have all the fun! yes
Spider1V devil
mre1
mre1's picture
I'm sure it's not the case but for the record my experience with distributor cap problem was related to water pump front seal leak.
Water pump front seal leaked and sprayed the cooland all over the place including dizzy cap area. Result - syrup like drops inside the dizzy cap. First they looked like water drops but i tried to wipe them of they were sticky syrup-like. Most likely the coolant entered the dizzy cap through vent holes in form of fume and condensated on the cap surface.
Changed the water pump, cleaned the dizzy cap and it worked as it should.
