280 GE Radiator
1 reply [Last post]
Hello Forum,
Having one massive mental block; could you please tell me if the 280GE automatic radiator has the gearbox oil cooler as part of the radiator or is that separate like the engine oil cooler?
Secondly, has any one photos of the radiator showing the pet cock (that is the drain plug). May I have and use it please?
axel
axel's picture
Re: 280 GE Radiator
here it is rakesh ,as promised two images  showing the 280 ge auto radiator with the bottom mounts /hose connection and the two oil cooler connections and the hex headed drain bolt just next to the right hand (as we look at it in the picture) there is a cutaway in the front skid plate for access with a socket to undo it .hope this helps your mental block.
