Wheel bolt torque settings
Wed, 01/04/2015 - 07:58
Can anyone tell me the Wheel bolt torque settings for a 461? I had just removed my wheels and had to use a 3/4" drive with a pipe to get the bolts loose, if I had had a puncture on the road I would never have got them loose with the original wheel brace!
Wed, 01/04/2015 - 10:55
#2
Re: Wheel bolt torque settings
180 Nm for steel, 130 Nm for alloy
The steel wheel bolts should be 58mm long compared to 69mm for the alloy bolts. Note the bolts look similar but do not use alloy spec bolts for steel wheels as the shoulder is slightly different and will cause the bolts to work loose.
Wed, 01/04/2015 - 13:18
#3
180Nm there is no way you would achieve that with a small wheel brace. 36kg at 500mm distance
I forgot to mention they are steel wheels.
