What does it mean when it says' Check gas cap' on the dash- But it isn't petrol cap?
Had the above wording (or similiar) come up on my dashboard a while back but not anything to do with the filler cap.
Now engine mangament light is on all the time. Clear engine mangement light and after a while the same comes up on dash,
Is it a fuel purge system problem and what's the easy fix?
Thanks in advance
Andy
Re: What does it mean when it says' Check gas cap' on the ...
Andy,
Not sure what G you have, however I did a google search and came up with the following, hope it is of use?
http://answers.yahoo.com/question/index?qid=20120224190641AAbgAQM
Spider1V wrote:
Andy,
It's a 500 baby!!! I think they are fitted with a V8 petrol engine....sure somebody will correct me ;)
gav.helme wrote:
Spider1V wrote:
Andy,
So a proper G Wagen then.... winkdevilyes
Let us know how you get on!
It is quite possible the fuel filler cap is not tighten properly or has a perished seal in which case get a new seal or new cap and replace as necessary. the Engine light will need resetting although by my understanding the light can go out by itself after a few cycles of the light coming on and settling down. - source of information Mercedes Benz forum.
Rakesh
drewtee's picture
Ok i'm going to check the fuel cap in the first instance.
My mechanic nearly put in and ordered a charcoal filtration system without doing this (£183 plus vat) so i will check the cap first.
