W463 Fenders
Thu, 11/09/2014 - 14:01
Can anyone tell me if a new 463 front fender is supplied with the mountings for the headlamp surround (items 14 & 80)
Thanks in advance, Gordon
Mon, 15/09/2014 - 07:53
Re: W463 Fenders
Yes Gordon they are. When you check on EPC part number listing you will see two dots in front of item 14 this denotes it comes as part of the next larger assembly and the one after that. In front of item 80 there is one dot which means it comes as part of the higher assembly. ie item 14 is available separately, if you order item 80 then item 14 comes with it, if you order a fender then items 14 & 80 come with it.
Hope this helps and hope to see you at the AGM
Regards
Kevin
