w463 air con system
8 replies [Last post]
stevo
stevo's picture
Hi all does anybody know of a air con system for sale for  a 1992 w463 g wagen it  has to be fitted in a G300 petrol rgds steven
Re: w463 air con system
Looking for gold dust there; I expect the equipment under the dash is a Mercedes must, all other items can be second hand from donor vehicles thus reducing some element of installation costs.
Alternatively, install a Motor home type air con system - true the vehicle will have additional height to it.
SierraTango
SierraTango's picture
Sorry bit of a thread hijack, I thought that the south east asians had solved the issue with after market air-cons back in the eighties without the use of large units strapped to your roof! When I was living in Hong Kong before A/C was a regular manufacturer installation, I remember seeing in every taxi you sat in, blower units bolted to the underside of dashboards obviously with a compressor in the engine bay. I don't understand why it's such a difficult and costly operation now if there were obviously off the shelf units available then? I've never seen anything like it over here but neither have I found anything on the net, which I find odd.
Ljg458
Ljg458's picture
my 463 has air con but it does not work :( expensive repair ? main dealer or can someone else sort it ? i was told that air cons rare in the old 463s but i dont belive it
Roly
Roly's picture
The a/c was an expensive option on the early 463s. The 300GE tended to had it, but alot don't. Possibly rare is not correct.
Any decent a/c service centre will be able to fix it
Few things here:
Does you G have a factory air con unit?
Has it worked since your G Ownership?
If so, for how long?
It could be that it has gone in to auto shut down, because it needs re gassing. This now opens up a load of other challenges , do you use R-134A or R-123. When the MB supplied aircon drop below a certain pressure/ amount it will shut down and stop pumping, if that is the case, how long has it shut down? I ask as if it has been a while, it begins to grunge up and (if possible) will need a good service.
I do know that ATS can do the recharge and they can have a look at it for you. Failing that I am stumped.
HTH
You do not have to go to a Mercedes dealer to have air conditioning sorted out. Find an air conditioning specialist in your locality and they could sort you out. If your system is not working, most likely due to a low refrigerant charge. Your specialist will firstly check for any leaks in your system and rectify that before going further. Spider IV has touched on a very valid point, what gas was in the system before leaking out. You can have the gas converted but I am not up-to-date on that, some say they can change the gas without any working on seals and rubber being done but I have contrary information and have not looked into this in earnest, so I do not know. I would suggest asking around from a few different specialist to see what the consensus is.
You may be advised to renew the moisture remover/dyer this can reduce the efficiency of air conditioning cooling. Think of it as an oil filter, when it get clogged lubrication is effected.
A good air conditioner specialist may need to add some refrigerant oil to keep the system to allow for lubrication to occur.
After your work has been done, do use your air conditioning 10 mins to 15 mins each month to help circulate this oil around in the system which helps keep the oil seals supple and maintain sealing integrity and keep the air conditioning running for longer. None of this re-charging malarkey every year. My system has lasted over six years and I have not charged up my system yet, it works fine. Note: air conditioning has its uses in winter too. Whilst blowing hot air during winter do use the air conditioner as dehumidifiers in the system keep the window from steaming up, the dry windows keep them clean in that way, none of the hand screen cleaning worsening screen vision as a result.
I would suggest perhaps every year to have the air conditioning cleaned out with anti- bacterials, your specialist may ask from you if you want this done. Have this done in particular if you carry little kiddies sneezing in winter.
G-Restorations
G-Restorations's picture
Hi Steve, I know where there is one.
Give me a call 01253 892293
Ljg458
Ljg458's picture
wow ok cheers guys ill get onto this now
