Viscous coupling
17 replies [Last post]
mjamo
mjamo's picture
The visous coupling on my 300 GD has seized solid, and i thought surely can't be too expensive, how wrong i was. Mercedes quoted me today £300 + vat :o
Does anyone here know where i can buy one cheaper or maybe info on fitting an electric fan?
Many thanks
mortinson
mortinson's picture
Viscous coupling
What model and year are you referring to?
mjamo
mjamo's picture
Viscous coupling
its a 460 on a 1986
mortinson
mortinson's picture
Viscous coupling
You are right.... it is listed as € 402.91 + VAT in Germany, so it's not surprising.
I would try EUROCARPARTS:
http://www.eurocarparts.co.uk
German Swedish & French
http://www.gsfcarparts.com
BlueStar
01740-631954
KMS
http://www.kmsparts.com
Russ280
Russ280's picture
Viscous coupling
Just bin it and fit a Kenlow.
Or if you are up to it go to the local scrappy and get a suitable electric fan off a scrap car.
John
John's picture
Viscous coupling
Thought you were taliking bout the wife, then a saw it was viscous not viscious coupling.
mjamo
mjamo's picture
Viscous coupling
Fitted new pacet 16" electric fan and it works a treat, and only cost £109,
mortinson
mortinson's picture
Viscous coupling
Can you give more details? If only for the savings on fuel this is a good mod. Cheers,
mjamo
mjamo's picture
Viscous coupling
Do you mean how i fitted it, where i purchased it etc, or benefits of fitting one?
mortinson
mortinson's picture
Viscous coupling
Well, the benefits are clear.... I meant what model, where to get it from and tips for fitting it..... specially to be able to compare it with the Kenlowe that Greeney has fitted to his car.
amokwa
amokwa's picture
Re: Viscous coupling
My viscous clutch is not working can someone advise on the Pacet fan fitting :
Slimline ?
Is it setup to push or blow the air ?
Vehicle :
'92 300 GES
Could you please furnish your Chassis No: and, or your Registeration No:; I have any enquiry on going for you on this topic.  This is for an alternative supplier for the viscous coupling.  If you could manage the engine number, that would be nicer still, viscous couplings for you model are engine number related.
Thinking about this, was your fan freely turning before?  My experience of failed viscous couplings are that, they usually fail in the 'fan free' position, hence the tab to permanently lock the fan for cooling in an emergency.  They could fail in a locked position, I suppose, but I feel this would be extremely rare.
cheers,
amokwa
amokwa's picture
Hi Rakesh,
Thanks for your help on this, the fan does run freely however I do not see any locking tabs may be a non OEM clutch ?
Below are the engine/chassis details you requested :
Engine : 103987 22 001482
Chassis : 463 2272 707 6343
I removed the thermostat yesterday and noticed a drop in cruising temp. from 95/100 c to 80c however it still climbed towards 120c when I got stuck in traffic.
Regards,
Sam
Hello Sam,
As temporary measure, you can set your heating to hot and heater fan on to increase the surface area for heat to dissipate, this will help in reducing the coolant temperatue a little, you will need to turn down your windows though.
Secondly, in anticipated long and slow moving traffic, switch off the engine.
Thanks for you vehicle details, looking into viscous coupling supply.
Rakesh.
Hi Guys
MB Part Number A103 200 11 22 Viscous Fan coupling
Available at MB UK so dealer could order within 48 hours
£152.00 + vat at retail
Don't seem too bad?  10% should be easily negotiated?
PM me if you need further assistance
My last post was for the 300 GES W463 M103 Engine coupling enquiry
From the original post for a W460 300GD OM617
I work it to be £271.00 + vat
Available from MB Germany in 72 hours
Again 10% discount should be easy
And to Pistonhead i have not forgotton  the info
Just not got around to posting it as have been on hols
amokwa
amokwa's picture
Thanks for the info. Gav. I got the same quote from MB Brentford. Rakesh PMd me a contact. I ordered one of theirs £79 (Sachs) should be here next Tuesday.
Sam.
G-Restorations
G-Restorations's picture
Found this while trawling ebay   http://cgi.ebay.co.uk/FAN-COUPLING-VISCOUS-MERCEDES-VARIO-617-200-03-22-/200423487268?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2eaa2bb724
