Thanks for all your feedback,problem is now solved, R,
Time remaining: 0%
01/01/1970 (0 sec)
mark's picture
Re: set headlamps for 2006 400 CDI wanted,
I think you lose the internal height adjuster with the Golf lights.
463 820 01 59 is the RHD clear headlight .
Easily confused by some dealers with 463 820 00 59, which is the LHD clear headlight.
xr219's picture
can i buy one of your lhd ones?
mike
Raymondo's picture
Hi mike,sorry for the delay in responding, (yes) as soon as I get replacements, you can have both v. Cheap,  I also require a speedometer  in MPH/ KM PH regards Ray,
tel 01874 754435,
mark's picture
Why?
Your digital display should be able to show in MPH
Usually VW - Golf MK1 headlight lens fit the W460/3. Assuming these will fit your vehicle try these out.
http://www.ebay.co.uk/itm/vw-golf-mk1-Front-Headlights-/301074230414?pt=...
same used on Golf Mk2 as well H4
"Re: set headlamps for 2006 400 CDI wanted,
Submitted by mark on Wed, 29/01/2014 - 16:05.
I think you lose the internal height adjuster with the Golf lights."
If you transfer the lens onto you original frame work; one is able to retain the headlight adjusters, I think, but I cannot remember if the adjuster pops into the lens socket or not. But if you do not have working headlight adjusters it should not matter.
Thank you for informing us that your issue has been resolved. It is great closer to the thread and sadly only a few people do this, Thank you and well done for doing so.
