Speedo and a vibrating sound
Our speedo has suddenly become very jumpy at around 40 - 70 mph. When the engine is warm is seems to get a little better and more stable. Does anyone know what might cause this?
Also on a cold morning we get a vibrating sound rising and falling with accelaration coming for behind the dash again once engine is warmed up this goes away. The only thing I can see under the bonnet in that position is the break servo. The brakes are working fine.
Any help would be great.
Hamish
It's most likely that the speedo cable is worn through its sleeve lining and is sticking, making the speedo needle jumpy and giving a whining noise.
You should start by fitting a new cable. However, the worm, drive-gear that connects the cable to the transfer case also wears, so best to change both these items.
The speedometer clocks themselves also eventually fail, as the internal gears and bearings wear, but start with the above first.
Its a fairly simple job to thread through the new cable. You only need to remove the instrument binnacle and the lower knee panel (and steering wheel to get to the binnacle)
You might even be able to attach the new cable assembly to the old one and use it to pull the new one through.
The connection point on the transfer case is readily accessible from underneath. No need to remove gearbox or anything like that.
I did one 463 many years ago, but don't recall the details. Check MB WIS, if you have access.
On the 460, its even easier.
Perhaps that was for a 460 , 300gd manual, which I understand are as you describe, but for the auto, the cable attachment point is quite accessible on the transfer case.
Vibration / whining sound sorry
