Rear Mud Flaps
My 463 has no mudflaps. I read that the original MB side steps, which my car has, precludes having front mudflaps. About the rear muflaps, I attach a photo of the area behind the rear wheel (the plastic on the left side of the photo is the bottom of the inner wheel arch cover and the bar with holes extend behind that.) That bar has lots of holes in it but nothing attached. Might this be the bracket for mudflaps, in which case i need just the bolts and the actual flap?
thanks
Hi, yes, you are correct, there should be a mud flap attached to that bracket. There should also be a 'rail' that bolts to the other side of the mud flap to clamp and support it. See following link-
http://www.neoriginal.ru/cat/mb/part__2_1_59B_463_518_34G_463_207/88_115_
Done it a few times, that's the bracket mate.
cheers
463 Fronts with Side Steps a no go for Genuine Flaps..
Rears are pretty much the same across all models 460/463
Picture attached for reference
Shout if you need assistance
Just ordered the 12th pair this year
Circa £40 for just the flaps
Maybe more if you are retro fitting and need all the brackets, but most can be made easily
I would say £50 or so would get you a pair sorted from scratch?
i need a new rear mudflap set Gav.. Just the flaps not the brackets..
Do you have the part numbers left and right? So I can get the rubber bits at the correct price
John
Hi John Just to ease Gav's workload, though I'm sure he will correct it if wrong the part number is 460 889 11 05.. Pic attached Yes I have some, but I do keep thinking about putting them on now I have had the back end sorted i.e. replaced :-) Ive tried to attach a pic in case the label has other info you might need. Ta Simon
Thanks Simon, i had disappeared for a day or two..too busy :)
Left A460 889 11 05 £22.52 Each + vat
Right A460 889 10 05 £22.52 Each + vat
Bracket (140) are A460 882 00 27 £7.32 Each + vat
MBUK hold small stocks
PM if you need help
thanks Gav
will PM you if my dealer cant help..
regards
John
rear mudflaps now on order at the correct price of £27.02 each incl VAT
invaluable posts...
thanks guys..
John
Stainless bolts probably a good idea when you bolting them up, should you ever need to remove them.......
