Petrol tank vacuum
My petrol tank gets quite a vacuum build up (when I remove the petrol filler cap there's a big whoosh).
I'm only an amateur - so may be a silly question:- should there be any kind of vacuum build up? If not then I take it there's a breather pipe or hole somewhere that needs to be unblocked.
Is that easy to locate and clear? If so, simple directions would be much appreciated.
Are you sure it's a vacuum and not pressure?
For the 300GE, the tank venting is controlled though a carbon cannister leading back to the engine intake manifold though a controlled valve and also through a vent-valve leading to some pipes in the rear somewhere. There is also a pressure accumulator on the second fuel pump and if its membrane breaks, this can also affect tank pressure. Does the engine start OK?
Ok, so fule- pressure accumulator is fine , then,
Tanks usually build up some positive pressure, not least from evaporation.
Petrol evaporates easily at lowish temperatures, so it is possible that a change in ambient temperature from warmer weather and sloshing in the tank can cause enough vapor pressure to cause the whoosh you are hearing, when you open the cap. (In vacuum conditions, volatile liquids such as petrol will evaporate even more quickly, decreasing the vacuum, so i doubt it's a vacuum, which if it were, would also make the engine harder to start.) The management of fuel vapor in the tank is controlled by feeding it back to the engine after passing thorough the carbon canister. Excess tank pressure, however, is vented through another valve. To reduce hydrocarbon emissions, there is no open venting of the tank, which is why I am inclined to think that it positive pressure in the tank, which you are hearing. If this is very high, there may be a problem with the vent valve to atmosphere.
Mark,
did you ever determine whether you had a partial vacuum or positive pressure in your tank, because:
http://www.benzworld.org/forums/w124-e-ce-d-td-class/1712285-screwed-charcoal-canister.html
the charcoal filter is located under the right-hand, rear wheel arch, near the fuel-filler - opposite arch to the fuel filter and pump.. It will look similar to that in the previous link, but it's a plastic-cased unit, rather than metal-cased, so it should not rust away like the other example. But i understand that they are a 70,000 mile maintenance item and they can clog and gum-up internally, when they get old and then restrict flow.
I think in practise, these charcoal canisters are rarely, if ever replaced. They are clipped to the underside of the rear wheel arch and they have, from memory, 3 small hoses connected. Probably about 30 mins to change - same as a fuel filter.
But, I guess they can be checked with air and if not blocked, then probably OK to leave it.
Ah - good question. Will have to wait a couple of days, undo filler cap and try and work out if it's vacuum or pressure.
Turn key, no accelerator, engine fires straight away.
