Oil leak Rear axel tube
4 replies [Last post]
Grendle
Grendle's picture
 Got oil leaking from the rear axle tube on to my rear brakes on my 463. had this on my 460 and had to pull the shaft and fit a new bearing as the seal was part of it. Is it the same job on the 463?
     Grendle
Re: Oil leak Rear axel tube
Yes,I think,but you have abs sensor ring to remove. Not too expensive to buy removal tool or you could fabricate? I wouldn't dare chisel it off. Also maybe remains of a funny neoprene seal,which I think is too lubricate bearing on extreme slopes? Think you can do without it?some 463 have it,others don't
Grendle
Grendle's picture
 Thanks Jason,
    I'll have a word with my Bush Mechanic....if not off to Mercare!
          Paul
Hi Paul
Yes both same, at least for all Drum braked 463's anyway
Same Bearing and Seal kit as the T1 van A601 350 04 68 is the number for one side
£88.50 + vat at the moment
MBUK have just the one on the shelf if you need it quick
PM if you need help etc
MB Germany out of stock too at the moment, must be a supply / quality issue!!!
Just one UK dealer in Fareham with one in stock also
Grab them while you can!!! LOL
Looks like 4-6 weeks from MB Germany
A463 353 00 59 is the Seal / Thrower that Jason refers to that breaks up with the heat...£17.56 + vat and MB Germany have just 13 in stock
Grendle
Grendle's picture
 Thanks Gav,
    I'll nip up to my MB dealer tomorrow!
