Long Shot...Boot Locked Battery Flat R129
As above, anybody know if/where there is a point I can get some power in to my SL so that I can open the boot to charge the battery.
I've had a lot of suggestions on the MBClub board but no-one knows for certain.
You probably found this already, but just in case:
http://www.benzworld.org/forums/r129-sl-class/1354005-what-do-r129-dead-...
Eddie.
Time to knock up an anderson connector and leave it under the bonnet, so next time you can just plug into it.
I've seen some cars with a plastic screw on cap which hides a stud underneath, I assume you can just clamp a +ve jumplead onto it (and the -ve onto some earth point under there too)
If, under the bonnet you do not have a post as circled in red;such as shown below:
Then you could have a terminal marked 20/23 as shown in the illustration below.
In reality like:
.................................................................................................. What's an Anderson connection and how easy is it to knock up? .........................................................................................................................................................
Check out this link:
^^^^^^ That's the kiddies
If you've got an auto factor near you who sells Durite stuff, then they do genuine Andersons too.
175amp ones should be plenty, which are (durite) 0-431-75 for the grey ones, or 0-432-75 for red colour
I am aware you have resolved your issue but in my research one thing has been bugging me. Why did you not use your key to unlock your boot. Including and pre 1998 models have keys for the boot. Unless my sources are wrong or you have lost your master key.
Solved.
I fed some juice in via the fuse box, it was enough to open the boot.
