Lighting bulbs in dash
Can somebody explain me how I need to proced to change the lightingbulbs in the dashboard. It is a 463 model 250 GD, year 1990.
Half of the dash is black and the other side is not so eluminated as it should be.
Thanks for everey usefull info.
B.V.
Belgium
250 GD
When you say "dashboard", are you refering to the instrument cluster behind the steering wheel? If not, can you be more specific?
You will need the 2 special tools with part number 140 589 02 33 00 and follow the instructions contained in MB workshop manual 82.51, page 7.1/1, to remove the instrument cluster. I would assume that once this is done, you can access the bulbs beneath the cluster and replace them, but I have never done this.
As you can see in the pic below, the tools are nothing but a couple of hooks that you might be able to fabricate yourself.
Otherwise, your best best would then be to take the car to a MB garage or an independent specialist that has access to the special tools.
MB workshop manuals are available to GWOA members.
The dash board is not that difficult to remove. I have done it several times.
The tools that Jesus mentioned can easily be made from a piece of stiff wire like a welding rod or coat hanger. You only need to pull it 10mm and then use yourr fingers to avoid damage.
Prior to pulling the dash you must remove the steering wheel . This requires a 22or 27 ? mm socket a extension bar. Flip out the MB emblem carefully and the nut is down below. Its stiff so hold the wheel and get a mate to do the socket. Don't use the steering lock to hold the wheel as it may break.
You need to align the sttering wheel prior to pulling it so you can reassemble it correctly. There is no master spline.
The 2 bulbs are on the top left and right of the dash at the back.
I think you need to pull the speedo cable from the back of the dash to get it out. It only needs to come out far enough to get your hand to the bulb holder. Don't drop them behind as you will never find it again.
Nothing beats a bright dash when they have been out for a long time.
roly
Benoit:
That's absolutely brilliant! I did also replace the bulbs of the speedo/combined unit of instrument cluster of my older 460 series with more powerful ones and at such low wattages I don't think that it did any harm but at the same time it improved the appearance of the car at night exponencially.
Talking of which, I'd now like to do the same to my 463 series G and the question is: what type and MB part reference number are the 5w bulbs? I'd like to buy them before dismantling half of the car...
BTW I see that you own a 250 GD. Is it a SWB or a LWB? I would like everyone to fill the fields in their profile so that I don't need to ask these questions!
Benoit:
I guess that my 300GD must look like real quick compared to your 250 GD! However you can say that you own a fairly rare GWagen, of which very few were made. I asked if yours was a SWB or LWB because had it been a LWB that would have made it even rarer: only 16 were produced, making it the rarest of G-Wagens!
Regarding the bulbs, what size/shape are they?
Yes, it is what I mean !
During driving in the dark I can not read the instruments any-more.
