Intermittent alternator and dashlight failing '87 W460. How do trace fault?
Hi All,
Had long-term intermittent issues with alternator not charging (and been left stranded on a couple of occasions). Anyway, mistakes aside (like replacing alternator having not appreciated the clues the dashlight was giving), determined fault somewhere in the circuit supplying the 12V exciter lead that also illuminates the battery light on dashboard (did this by running a 12V jumper lead to alternator and hey presto all works fine). The bulb is fine (removed in picture), but how can I test contunuity when can't see any connectors to power bulb?
Suspect I'm missing something obvious, but any clues or thoughts to help resolve would be appreciated?
There is a multi-pin connector supplying the cluster, it might help to now what number (wire colour?) corresponds to the battery light? I did have a quick look at wiring diagrams, but I'm no electrician, not even sure looked at correct part!
Would be great to put battery charger back on shelf! Any help please?
Stewart
I did some digging and learnt a bit. I think you have a 1986 G300D ?
Option 1:
This is one of the top causes on W123 diesels.
- The alternator needs initial "excitation" current through the dash charge warning light to start generating power (a classic Lucas/Bosch design feature).
- When you turn the key to ON (engine off), the light should illuminate. If the bulb is burned out, missing, or the socket/circuit has poor contact, there's no excitation path → no charging even with a brand-new alternator.
- Fix: Check if the battery/charge light comes on with ignition ON (engine OFF). If not, replace the bulb (it's in the instrument cluster). Also clean the bulb holder/contacts. Test continuity across the bulb circuit.
Option 2:
Many aftermarket or remanufactured alternators come with cheap/faulty internal regulators, or the regulator fails soon after install.
- The regulator (with brushes) is a common weak point and can be replaced separately without buying a whole new alternator.
- Fix: Remove the alternator (or access the rear), unscrew the regulator cover, and inspect/replace the regulator (Bosch part or equivalent is inexpensive). Many owners report this fixes "new alternator not charging" issues.
Option 3:
The alternator has a multi-pin connector (often with two thick red B+ wires and smaller wires including the D+ excitation wire).
- Loose, corroded, broken, or miswired connections (especially the thin D+/excitation wire) prevent charging.
- Previous owners sometimes modify wiring, or the plug gets damaged.
- Fix: Unplug the connector, clean contacts, check for voltage at the D+ pin (should get ~12V with key ON from the dash light circuit). Inspect the red wires for good tight connections to the battery/alternator output.
Try the first option, since you clearly have NO dash Bulb installed... and if you then need to check the connection from the alternator to the bulb (option 3), see if this helps:
The multi-pin connector on the alternator of a 1986 Mercedes 300D (W123 with OM617 engine) is a 3-pin (or 3-prong) plastic plug from Bosch. It connects to the rear of the alternator and handles the main output plus excitation.
Typical Configuration
- Two large/fat terminals (often the bigger slots or pins): These carry the high-current charging output (B+).
- Wires: Usually two thick red (or red/white) wires.
- Function: These are paralleled for higher current capacity (one often routes to the starter positive post, the other to a nearby terminal block or directly toward the battery positive). They should show constant ~12V battery voltage at all times (key off or on), as they're direct battery connections via heavy cables.
- One smaller/skinny terminal (the narrowest slot): This is the excitation/indicator wire (D+ or sometimes labeled as the warning light circuit).
- Wire: Thin blue (or white/blue in some descriptions).
- Function: Provides initial excitation current from the dash charge warning light bulb to "wake up" the alternator. With ignition ON (engine OFF), you should see ~12V (or slightly less) here from the instrument cluster circuit. Key OFF: no voltage. This wire also feeds the tachometer signal on some diesels and lights the battery warning lamp if charging fails.
The plug is keyed/asymmetric so it only fits one way— the two large pins are typically side-by-side or in a row, with the small one offset (often the smallest slot is for the blue exciter wire).
Visual Layout (text representation, viewing the plug face/male side on the alternator or female harness side)
Large pin (B+) Large pin (B+)
Small pin (D+)
- Exact orientation can vary slightly by year/production, but the small pin is consistently the exciter (D+), and the two larges are B+ outputs.
Quick Tests at the Connector (unplugged, multimeter)
- Key OFF: ~12V on both large pins (to ground); 0V on small pin.
- Key ON (engine OFF): ~12V on large pins; ~12V (or bulb voltage drop) on small pin → confirms dash light circuit is feeding excitation.
- Engine running: Voltage on large pins should rise to 13.5–14.5V if charging works.
If your new alternator has spade terminals instead of a plug (some aftermarket do), the main B+ is usually a large stud/bolt on the back, and D+ is a smaller spade (often marked "D+" or "61"). The harness plug may need adapting, but stock is the 3-pin as above.
Thank you for very detailed answer! And yes, car was built 1986, but UK registered 1987 (means another year tax etc.)
I suspect however my questions were not clear. The alternator fault is intermittent (unfortunately mostly doesn't work, but can come on when driving*), and as you note (and I've be able to determine), lies somewhere in the 12V exciter lead that runs via the dashboard bulb (the bulb itself is working). In the image I have removed the bulb (it can be seen resting to the right). These have no direct leads but connectors that must line up with some type of printed circuit on the back of the dial. I would like to access these hidden connectors to test if the fault is in supply side, the lead running to alternator, or in the bulb connection itself?
To eliminate possible supply issue I could check the incoming leads to the multi-pin white socket (top of image) - what colour wire or socket number is this? Likewise what is the socket number for the feed to the alternator?
And I suppose the next question could be is taking the dial apart to check internal and then the actual bulb connections straightforward? No hidden springs or risks?
Stewart
*I have purchased a simple voltage display that plugs into 12v socket and have studied this a lot... well to much actually!!!
