Hydraulic cylinders on front and rear axles
Wed, 07/01/2004 - 19:21
Does anyone know where to get the axle mounted slave cylinders on both front and rear axles? I would also like to hear from anyone who has fitted heavy duty springs to a SWB 'G'.
John
Wed, 07/01/2004 - 20:16
slave cylinders for what ? diff locks, or brakes. I have fitted springs to G, What do you need to know, if you have a swb then buy long wheelbase springs from MR Holland who advertise in G-Wizz ( are you a member) The LWB are heavy duty and around £38 each and take an hour to fit
Sorry Peter, thought when I said axle mounted it was clear it was diff cyls I was on about (as opposed to brake backplate mounted).
Re - springs. I am using 'soft' standard springs on my SWB, I want to know how dramatic the effect is on ride quality and handling with HD springs, which I know are the same as the LWB from the G-Wizz mag.
I do appreciate any info.
Regards
John
