Diffs
Sun, 13/12/2015 - 18:40
hello,
Which G's have a 34:7 front diff and which have 37:7 a front diff?
The code on the diff of my 300ge is : 460 335 0412 34:7
Is this right? Doesn't it has to be 37:7?
Thanks for your answers.
Best regards from Belgium
Sun, 13/12/2015 - 18:49
Re: Diffs
Diesels are lower revving engines (than petrol), so likely to have the lower geared diffs. Otherwise, probably only G500 and later higher powered engines likley to have them. Gav will no doubt be able to tell you precisely.
There are also similar difference in the transfer-case ratios for high-range.
I can tell you that a 300 GE, Auto, will do around 19mph (30.5 km/h) per 1,000 rpm in 4th gear
