Dash / Clock Lights?
Thu, 13/11/2014 - 22:29
I seen somewhere on a US based forum, a guy who had fitted LED's in place of the dim bulbs to a W460. Anyone know what size and how many are needed before taking the clocks apart?
Thu, 13/11/2014 - 23:16
Re: Dash / Clock Lights?
I've done it red .it was to dull and blue was to bright.i will take a picture.
the way led light spreads is not the same and the old circular fittings are a nightmare
but still looks better than original
Fri, 14/11/2014 - 21:40
#3
Sat, 15/11/2014 - 15:40
#4
Do they fit in existing lamp holder? Or are there adapters? How does the upgrade work? Certainly the original bulbs are pretty poor...
I'd like to try a the upgrade, if it's not too finicky...
Did you use replacement bulbs? or did you wire in LED's?
If your LED's are not giving equal light, a trick i have used in the past is to sand the tops flat as this stops the light 'hotspotting'.
Interested in seeing the pics and method :)
