Cup of Coffee Test
34 replies [Last post]
Hello All,
Just wishing you all a Happy New Year.
I also wanted to post this. A few weeks back there was a post about the smooth running of V8's v's S6's. Got me thinking and so with the help of 'Hello Kitty' please find the results of the test this morning. Seems smooth to me.
https://www.youtube.com/watch?v=mDeXrSRZQsQ&feature=youtu.be
look Forward to seeing y'all in 2015!
IanA2
IanA2's picture
Re: Cup of Coffee Test
You've reminded me of something I meant to post a long time ago.
Whilst filling the LPG tanks up I usually put the caps (like the one below) upside  down on the bumper. Having filled up I went off, did a few things and about twenty five miles on mixed town and country roads.
When I got home at first I groaned when I noticed a missing cap, another fiver I thought, until I spotted the cap exactly where I had left it! Extraordinary.
Spider !
In case you don't know how it works smiley .
needamerc
needamerc's picture
That coffee sounds a bit tappety to me devil
nedvaughan
nedvaughan's picture
Must try that on me little 2litre kitten :)
John757
John757's picture
anyone know how to clean coffee off a rocker cover?  laugh
evista
evista's picture
So, i tried the cup of coffee test at the weekend, albeit with a cup of tea.  The results were fairly as disappointing with a lot of rippling and just a bit lumpy. Hopefully this link will work:  https://www.dropbox.com/s/e1v6ynoh47amrrm/Video%2002-01-2015%2009%2044%2004.mov?dl=0
I had noticed that the engine wasn't that refined on tickover and this was something that the mechanic mentioned when dropping the car off after having a service and new set of plugs.  He advised that it was a very slight misfire when ticking over but was fine when running under load.  No need to do anything about it, but if i did want a perfectly smooth tickover that you would get on an S Class, he has suggested replacing the HT leads.  I received the quote today to replace the 16 plug caps and ignition leads and the total came to an eye watering £700.  Now this mechanic is ex MB who comes highly recommended and the work he has done for me so far and has quoted for other stuff is very reasonable so I've no question about his labour costs but being ex MB mechanic, he has recommended MB parts although suggested I could go for cheaper alternatives.
Questions I have are;
1. Is it likely that replacing these parts will result in a more refined tickover?
​2. Is there any substantial discount available through the club for replacement MB parts?
3. Are there cheaper alternative brands that i should consider?
4. Should I ignore the tickover (as it's not really an issue) and spend the money on the replacement V8 exhaust with twin exit pipes which I have booked in for Monday?
Thanks in advance.....
1. Over time the HT leads do 'break down' as in they will degrade and if they are the same leads as when the car was new, I would recommend changing them and the sparks as well at the same time. I saw an improvement. If there is a misfire, then it could be rectified by new HT cables.
2.Speak to Gav Helme, I know I did not pay that!
3. The strength in the V8 Engine is to keep them fed with official parts, in my experience.
4. Are you speaking about twin pipes like an AMG? (having two sets on each side?) and coming out UNDER the side step? You will lose ground clearance if you are going to go off road!
HTH
Spider,
nice video - amazing what balancer shafts can achieve!
i won't try that on my V8 diesel !
From the colour of your expansion tank, it looks like you are using a Red OAT antifreeze in your engine?
If thought OAT antifreeze was not compatible with MB engines and should be the Blue Glysantene version?
John757
John757's picture
you can get genuine MB leads from Starpartz for a fraction of the cost Mb sells them for... all genuine old stock.... they list mine at £8 a lead which is substantially less than you are being quoted...
Often, the ignition parts are made (OEM) by Bosch or Beru and you can buy these directly through their distributors
John757
John757's picture
i thought V8 engines were a little lumpy at tick over due to their piston firing order and their v configuration engine ... love the twin exhaust idea.... who is doing that for you? Paul (P&R) mentioned the HT leads when he tuned my engine... but i had already replaced them with high quality aftermarket ones... which i have found are an improvement, if yours have broken down a good quality set will be as good. MB are being greedy in my experience charging so much for such a widely available part. you can even get a set custom made for considerably less.
Arnie wrote:
Spider,
Arnie - many thanks the Mrs was giving me rather strange looks when I said I had to do the test with the help of Hello Kitty!. Hmmm you raise an interesting point on the Anti Freeze - for as long as I have had the G when ever its been serviced it has been supplied with the red antifreeze, even when I had it serviced by Mercedes at Brooklands. Looking around at other G's I noticed that they too have had the Red stuff. Could it be one colour for Petrol and one colour for diesel?
evista
evista's picture
MB charge £32 + VAT per lead but through GWOA, I will see what discount there is  avaioable.  Failing that, Starpartz and charge around £14 + VAT for a set made by Beru.  Whilst I appreciate what Spider says about MB original parts, that is more than double the cost and I question whether you get twice the benefit out of them.
As for the exhaust, I found this place via John757's post about a guy in Brixton who does custom exhausts.  Having read a lot of horror stories about the likes of Vortex, CSK franchise's etc, I went and saw this guy (he's now moved out to Chelsfield in Kent) and he seems to be an enthusiast/perfectionist/ thoroughly nice guy so I've decided to give him a try.  Anyone interested in a new exhaust, it's worth reading this post  http://www.pistonheads.com/gassing/topic.asp?h=0&f=23&t=1172460&i=999999&nmt=Solid%20Fabrications,%20Brixton and I will of course update you with my own experience once my work has been done.
I'm having a CAT back replacement with one set of twin pipes exiting on the drivers (right hand)side.  Yes, they will restrict ground clearance but that is never going to be a consideration for me as I have no need to go serious off roading.  I do however love the sound of a V8 rumble, so for me I't's a worthwhile compromise.
The Red OAT antifreeze with carboxylate corrosion inhibitors is supposed to have a much longer service-life than the blue stuff with silicon-based corrosion inhibitors. HOWEVER,, the two types are not compatible and a thorough rinse-out of the cooling system is required if switching between the two types.
My car has not been to an MB dealer for ages, but both my G400 and G300 use the blue coolant and always have. The OAT has some advantages with all aluminium engines, but also some reports of other problems with it, Although Ford and other manufacturers have been using it for many years, Ford recently stopped using it because of various problems.
I don't know if  MB policy changed at some point to use the red OAT antifreeze - perhaps so, if your's has been maintained by an MB dealer. However, my research, below, shows that most likely you should be using either G-05 or G-48 antifreeze formulations, which are not OAT based. (although some G-05 versions may be 'hybrid' with small quantities of selected OAT compounds). Importantly, the G-05 formula also contains nitrates, which help prevent corrosion of steel cylinder liners (eg in newer diesel engines), but this is not an issue for all-aluminium engines without liners.
Most antifreeze is ethylene glycol based, but there are different corrosion inhibitors used in different versions. The MB-approved blue/green versions use silicates (Europe) which form a protective coating on the metal surfaces, but have a relatively short life so  the coolant needs to be changed approximately every 3 years. Other versions use phosphates (USA) or a combination of both. The OAT versions were developed for asian vehicles and do not contain silicates or phosphates: They protect by chemical reaction with the metal and because they do not form a 'protective' coating on the metal, as with silicates or phosphates, they provide for better heat transfer. However, the 'chemical reaction with metal surfaces' is what can cause problems unless all the metals in the engine are compatible, which may not be the case with cast-iron blocks and other parts?
If your engine materials are fully compatible, the OAT versions have by far the best performance, but check, because if not...
Read more here:
http://www.machinerylubrication.com/Read/841/coolant-fundamentals
some general info here:
http://en.wikipedia.org/wiki/Antifreeze
If you look at the Coma website, they produce/market all the different versions of antifreeze, including general purpose, as well as the manufacturer-approved types. The manufacturer approved types are made with BASF (German) solutions. Of the manufacturer-approved types, you will notice that their RED OAT-additive G30 versions do not carry MB approval. However, the blue/green G48 version, based on BASF Glysantin G48 formula does  But, also there is an Si-OAT  (G40) version (Purple), which has MB approval. This latter one is a hybrid silicon-OAT type.
The approvals for the Red, OAT version are fewer and mostly for relatively newer vehicles..
http://www.commaoil.com/passenger-vehicles/products/subcategory/13
OAT: (Red) - carboxylate inhibitors
Official approvals:
Glysantin® G30® by BASF is approved by: VW/Audi/Seat/Skoda/Bentley/Bugatti/Lamborghini (TL774-D/F); Jaguar from 1999 (VIN 878389); Porsche from 1996; MINI Cooper D between 2007 and 2010; DAF; MAN (324 SNF); MTU (MTL 5048)
Si-OAT  (Purple)  (hybrid technology)  - Silicate and carboxylate inhibitors (hybrid)
Official approvals:
Glysantin® G40® by BASF is approved by: VW/Audi/Seat/Skoda/Bentley/Bugatti/Lamborghini (TL774-G) from 2005 onwards & Porsche 911, Boxster, Cayman, Cayenne, Panamera from 1997 onwards; Mercedes-Benz (325.6); MAN from 12/2011 (MAN 324 Typ Si-OAT); Mercedes Trucks from 10/2011 (325.5)
Ethylene Glycol (Blue/green)  - Silicate inhibitors
Official approvals:
Glysantin® G48® by BASF is approved by: VW/Audi/Seat/Skoda up until 1996 (TL774-C); Rolls-Royce (from 1998), BMW/MINI BMW (except MINI COOPER D from 2007 to 2010) (N 600 69.0); Opel/Vauxhall up to 2000 (B 040 0240); Saab (690 1599); Volvo (1286083 Issue 002); Porsche up until 1995; Tesla; Jaguar up until 1999 (VIN 878388); MAN (324 NF); Mercedes-Benz/ Smart/Maybach (325.0); Van Hool; Volvo Truck up until 2005; MTU (MTL 5048)
Ethylene Glycol (Yellow)  - Silicate inhibitors - Heavy duty - version of above, 6,000 hr life
Official approvals:
Glysantin® G05® by BASF is approved by: Chrysler (MS-9769); Mercedes Benz (325.0); MAN B&W (List 3.3.7); Cummins (CES 14603); Ford North America WSS-M 97B51-A1; MTU (MTL 5048);John Deere (JDM H 24); JCB (STD 00088)
Not saying that the G is an 'historic vehicle' but here's some other info:
http://www.mg-cars.org.uk/imgytr/hints&tips/antifreeze.pdf
....and more information here:
http://www.motor.com/article.asp?article_ID=816
'...The inhibitor 2-EHA (OAT) poses another issue: It's a plasticizer (softens plastic), so it has been blamed for coolant passage gasket leakage. Softening (and the resulting distortion) was reported by Ford, which encountered gasket leakage problems when it tested a DexCool-type formula on its V8 engines. Ford also saw similar issues with other gasket materials. That killed the OAT coolant idea for Ford, which had used a DexCool-like coolant in the '99 Cougar V6. ...'
What Preceded OATs ?
'....Until the extended-life OATs came on the scene, there had been primarily two major coolant inhibitors for aluminum protection-silicates and phosphates-and conventional American coolants have used formulas containing both of them. Silicates are related to sand, and there were questions as to their effect on water pump seals. Some old tests seemed to suggest they were harmful, but there has been no credible evidence to support that stance on late-model designs with reputable brands of coolant. In fact, today's carbide seals are about as durable as you can get, and silicates that remain in solution seem to produce no problem anywhere. In real-world evaluations, there's no evidence of any issue, as silicate inhibitors have been used successfully for many decades in all makes of cars. Where a seal-deterioration issue surfaces, it has been attributed to core sand, from failure to clean engine blocks properly.
Silicates protect very quickly, so if there's some mechanical breakdown in the silicate protection, it re-forms very rapidly. For example, a water pump may suffer cavitation erosion/corrosion (a high coolant/ambient temperatures issue, particularly with certain cooling system designs). That means that as the coolant passes through the pump, bubbles are produced, which then collapse with explosive force, pockmarking the internal parts of the pump. That pockmarking is erosion, the marks being exposed, unprotected metal. If the inhibitors work quickly, the damage stops after minor corrosion. If they work slowly (as with organic acid inhibitors), the pockmarked areas corrode for a longer period.....'
and finally... an article from the SAE:
http://articles.sae.org/11284/
Daimler sticks with silicate-based formula
Silicates eventually are depleted in normal operation, and there are severe laboratory tests that cause it to drop out of solution. Those Asian companies that require these tests, primarily the Japanese makers, will not use silicates. Their phosphate alternative has a similar coating action but is not as durable and depletes over time. It also will not pass European car makers' tests with extremely hard water, with which they form scale deposits.
However, phosphate does enhance protection. Without it, Japanese makers have said, antifreezes will not pass their engineering tests. Asian service intervals typically are up to five years or 100,000 miles.
One major automaker still using a silicate formula with a long service interval is Daimler. Its engineering approach permits a service interval of 15 years/150,000 miles. Daimler’s “secret” is a silica gel packet, similar to what is used with electronics packaging, in the coolant reservoir. Daimler has found it gradually releases enough silicate to “refresh” the antifreeze. However, it recently replaced the G-05 with G-48, another low-silicate formula with sebacate, only a dash of 2-EHA and reduced borate. The two are compatible, and Mercedes dealers are treating them as interchangeable.
BMW and VW/Audi also use formulas with low silicate content in combination with similar OAT mixtures.
Unlike G-48, G-05 also contains nitrite, an additive that helps prevent diesel wet cylinder liner pitting corrosion. It reportedly was part of the protection package that Daimler required when it first approved the formula over 30 years ago. Nitrite cannot be used in an OAT formula, but diesel engine OEMs have found that the diesels in their cars and light/medium duty trucks enjoy satisfactory life with the OATs. The Cummins diesel, for example, passed Chrysler testing with its OAT, Lawrence said.....'
excellent post, thanks
Thanks. just found some more data here:
http://www.benzworld.org/forums/w210-e-class/1589546-need-help-alternati...
There's a good downloadable PDF article, which summarises better what I was trying to say above.
The range of G-Wagen engines are covered by specification sheet 325.0 for coolants/antifreeze/corrosion-inhibitors. This specifies either a yellow, G-05 (with nitrites) or a blue/green G-48 coolant. Both with a 3-year change interval.
The G-30 type , OAT coolant is only mentioned in sheet 325.3, but is applicable only to a few commercial vehicle engines.
Roly
Roly's picture
The v8 doesn't use balancing shafts.
Before replacing the leads it would be worth getting the engine connected to a MB Star diagnostic machine. It will be able to determine whether there is a misfire and what component is causing it. It measures the electrical components and acceleration of the crankshaft, compares it to expected results and gives a conclusion.
Griff
Griff's picture
We had liner pitting (cavitation) on CAT engines on the opencast sites engines I worked on we used 50/50% antifreeze this was recommended by Cat it reduced the cavitation and was a good corrosion inhibitor.
You can't stop the cavitation I've seen engines holed in the liner letting fluid into the engine then found out the site hadn't followed the rules and just used pond water which turned out to have lots of corrosive minerals in.
I use about 40% mix in my 290GD engine this link tells you about the problem it's a fleet guard filter & Cat bulletin
https://www.cumminsfiltration.com/pdfs/product_lit/asia_pacific_brochure...
https://catoilandgas.cat.com/cda/files/760487/7/PEHP9554-03.pdf
could it be the crank sensor?
Roly
Roly's picture
Joe
Unlikely to be the crank sensor, they tend to fail completely causing the engine to stop. Misfire could be a single lead or power pack which can be replaced rather than the entire 16.
What are you doing with your exhaust?
There should be both a camshaft sensor as well as a crankshaft sensor. The ECU compares both readings and there is a fault-code for when a discrepancy is noticed. This is the M113 engine, right?
Might be worth checking and cleaning the idle-control valve to ensure it moves freely. They tend to collect some dust and dirt and become sticky.
(I was thinking of the V6 version, with its un-optimal 90 deg Vee, that has the balancer shafts, Although I note that on the new V6s, MB has returned to the optimal 60 deg Vee and done away with the balancer shafts. Don't know why they originally used a 90 deg Vee, except for maybe cost reasons of commonality with V8..)
consur
consur's picture
Back to the anti-freeze topic.  Thanks for an excellent post Arnie. The comment about corrosion subsequent to using pond water leads me to a rather basic question that I am unclear about.  I live in a very hard water region, does this matter if I use it to dilute the antifreeze or should I be using distilled water (I have a distiller which I use to run an autoclave).  Any of the experts know the answer to this??
I'm not an expert by any means but just check out your kettle, if its full of deposit, that's what will be happening inside your engine and its coolant pathways. South Wales though has exceptionally soft water
I think that apart from possible lime-scale build-up  (from calcium carbonate as in kettles), it was mentioned that elements like magnesium in  hard water will react with the protective silicates or phosphates in the antifreeze to form other scaly products. Phosphates are more susceptible to this than Silicates and for this reason MB (G05 or G48) antifreeze is silicate based.
It was said that either distilled-water (most hard chemicals removed through boiling/condensation)  or de-ionised water (hard magnesium and calcium ions replaced by sodium ions) should be used to dilute concentrated anti-freeze, but soft water from the tap is also fine. If you have one of those Brita - type water filters, that should also be fine.
consur
consur's picture
Thanks for the reply - I'll use distilled water (or go to Wales). I don't know what the G05 and G48 refer to but my MB dealer has provided their standard bottles labelled "nitrite-free MB 325.0" (part No A000989082510).
The G48 = "nitrite-free MB 325.0" (part No A000989082510)
G05 = "non-nitrite-free MB 325.0"
The nitrate is an anti-corrosion additive for cast-iron blocks and aluminium blocks with wet cast-iron cylinder liners
As most new blocks are aluminium nowadays, MB has switched from G05 to G48 formula - essentially the same but  without nitrite
(I think the G-numbers refer to the formula of the antifreeze formulas, made by BASF, eg Gysantin, G05, which is the original MB antifreeze)
consur
consur's picture
So does that suggest that an old 460 eg 280GE should have GO5?
I think that would be better as BASF G05 was designed specifically for tat era of engine and the antifreeze formula can be bought through the Coma brand, if no longer though MB
There was an article about MB switching antifreeze formulas and saying that the replacement (G48) still offers 'adequate' protection for cast iron.for the expected service life of the engine, but as G's tend to live longer than most other cars....
But, actually, looking at the BASF data sheets for both G05 and G48, in the published results for simulated engine wear, both show a similar good figure aluminium and cast-iron and also for water-pump cavitation protection. The main difference notable in the data sheets is that the G05 formula also shows good results for steel parts, which the G48 doesn't.. So perhaps cast-iron is not so much of an issue, then and either G05 or G48 should be fine, in this resect.
Also notable from the data sheets is that both are not so good at protecting copper, tin, solder, brass and those types of metal - both allowing some erosion/corrosion -  but G05 is about 4x better than G48, so if your 460 still has the part-brass radiator, then the former may be the one to go for. (or also if you've changed your aluminium 463 radiator for a copper-cored one)
Just bring the post back to the original topic, I was challenged by the Honorable Member for the Northern Region  - Gordon, to Balance a £1 coin on the same engine block. We call that Challenge Set.
Me being me - Challenge accepted
Me being me, again - Challenge Completed!
First a completed challenge bending the rules a bit....
https://www.youtube.com/watch?v=0OmH62tW48o
Then doing it by the rules
https://www.youtube.com/watch?v=JuVGjC5T43Y
Joking apart, I must say I only thought you could do this on Jaguar V12 Engines and surprised myself that I could do it on a G500 Engine, with a slight tilt.
Yeh but - how fast were you traveling at the time??
even with the blue tak it was still moving
Gandore
Gandore's picture
I would think not too fast if he was running backwards to film it. ;-)
Russ280
Russ280's picture
That V8 looks like it's running a bit rough to me Joe. I'm sure you'd be better off with a dieselcheeky
OK I cheated a little but there wasn't anywhere level.
https://m.youtube.com/#/watch?v=F9gP9xK98HE
evista
evista's picture
Calm is restored: after having the spark plugs and leads renewed , the G is running really smoothly now. Could certainly pass the cup of coffee or £ coin test although I cant pass the YouTube test to prove it.  The engine also feels much more responsive particularly in the lower Rev ranges.
Money well spent!
