Battery Drain Issue
10 replies [Last post]
rkl786
rkl786's picture
Hello,
I currently have a 1991 230ge lwb 463 model and for the past month I been having a battery drain issue. Its usally not a issue if I drive the G everyday but if I don't drive it for one day the battery will get drained down to about 11v.
I already replaced the alternator, starter, and battery. Doing a parasitic drain test on the G shows that 1.16 amp is being drained while the G is off. Taking off the fuses didn't seem to lower it, but rather taking off disconnecting relay I ABS did lower it down to .65 amp.
I figured it may be the disconnecting relay I ABS but after switching it with disconnecting relay II ABS the drain goes back up to 1.16 amp.
I am not sure where to go from here, it feels as though the problem is simple and close by but I just can't see it.
I attched a picture of the battery, on it you see there is a thin red wire and a thick red wire. The thin wire is for the lpg and the thick red wire controls the fuses and stuff inside. My questiong is, the that red wire suppose to be directly connected to the battery?
The second picture is the relay for the disconnecting relay I ABS, I looked up the number but could not find another one like it, what other relay could subsitute for it?
thank you!
Re: Battery Drain Issue
Can only help on the Relay...
HELLA
4RD 003 520-01 and 4RD 003 520-017
Cross refer to MB A000 545 83 05 and A000 545 86 05 and A002 542 74 19
The last number is circa £8.70 + vat from MBUK and is just a Generic 12 volt relay
Any German MB dealer should stock it also...
Not that i am faulting the GWOA and pleased you are here, just curious that if you are in Germany is there not much and plentiful information on forums over there?
LEONIDAS
LEONIDAS's picture
Do you have an after sale alarm fitted??, Have you checked the central locking system for undue drain when activated?? any telephone ot  satnav left on??
rkl786
rkl786's picture
No after sale alarm, no telephone, or satnav. I disconnected the central locking system and the amp did not go down.
Also yesterday I check to make sure again and the central locking does turn off when the doors are closed.
rkl786
rkl786's picture
HELLA
Gav,
thank you for info I will check out the MB dealer. I am sure there is but I just moved to Germany recently for work and my German need more work them G does
LEONIDAS
LEONIDAS's picture
Hi rkl786.
You mentioned that  you have checked all the circuits and associated fuses. May be you could try to check this. Disconnect the earth terminal from the battery and attach one   lead of a test light to the  cable end. Touch the other lead to the battery earth terminal pole. If the light glows, there is a constant  drain. If the drain remain undetermined, the problem is likely a sorted starter solenoid or a short in the wiring to the solenoid. Inspect the wiring and connections. If no short is found disconnect the wires from the solenoid until the light goes out.
Try removing the fuse for permanent 12v to the clock and  car radio.
Some radios become faulty, particularly the Becker  Traffic models and draw high currents when they should be off.
thank you!
It does not look tidy to attach wires directly to the battery but looking at your picture, a fuse has been circuited into the line, so that is fine.
It could be the relay at fault or what ever is after the relay circuit. If this is four or five pin relay you could possibly test the relay out. Alternatively, without refereeing to a wiring diagram, I am assuming it will be the wheel sensors after the relay in which case unplug one by one the wheel sensors and check for battery draw.
As you have had all the fuses out and with no change in battery draw, then it suggests to me that the draw is on an un-fused circuit but you have changed the battery, starter and alternator - I am thinking on your Over Voltage Protection (OVP) relay, this is the one with a 10amp fuse mounted on the top of the relay.
g wagon g
g wagon g's picture
a couple of posts before this someone said use a test light
If you have not got one just use a sidelight bulb. Put the little pin on to the battery negative terminal and the negative lead to the side of bulb
With your short it should light up. Next get someone to remove fuses and when the light goes off you have found the supply that is a possible fault
Check all items that relate to that fuse
Too easy let me know how it goes
rkl786
rkl786's picture
Pistonhead wrote:
thank you!
I got up early today and tested this out, and it worked. I removed the OVP relay and the drain went from 1.16 amp to .05 amp. The fuses on the OVP relay were fine so I assume that there was a issue inside the relay or the connector. Either way I ordered a new relay to test out. Thank you for all the help everyone!
Dave Cawley
Dave Cawley's picture
Was the relay energised ?
