Anyone help re trailer electrics
Went to buy a second hand smallish box trailer for my G (as you do) but the trailer had a 7 pin electrical plug which was incompatible with the electrical socket on the back of the G.
Anyone know of an adaptor that will connect to both the trailer plug and the G socket to save me chopping off the trailer plug?
Mark
How many pins does your G have?
Strange not to have the standard 7 pin plug?
I guess it could have a Euro 13 Pin?
If so i can supply a direct 13 pin to 7 pin that should work for around £15 (MB)
You can eBay them for less though..
Gav's beaten me to it, but this is what I have. 13:7 adapter
Hi Mark,
Just in case your trailer has LED lights make sure that all the signals work: sometimes the low current isn't sensed and the towing relay (double indicator on the dash board) doesn't light up and you think that there is a fault although everything is alright. No need to panic: for once the newer electronic solution really is better.........our older cars just can't recognise it.
Ph
.....Frightened to ask - but how much would a set of MB side steps be for a SWB G463?
Mark
Around £900, the last time I enquired from MB, some months ago. However, none available. either here or in Germany.
(The SWB G models have been out of production since about 3 years ago, and so maybe SWB side steps, too.)
mark not sure but i think some one did that or similar
and some thing or other did,nt work
cant remember the details
If your truck is fitted with Mercedes reversing beepers you may find by leaving the adapter in the bleepers will stop working.
Thanks Gav,
G has a 13 pin - so have ordered one from Amazon @ £5.75 with delivery tomorrow (how do they do that?)
Mark
