460 lightswitch - rear foglight warning light, how to change the bulb?
Thu, 02/04/2015 - 21:49
MOT Tester has pointed out that the little orange light that indicates when the rear fog light is on doesn't work. Haven't been out in fog for years so hadn't noticed. Can't work out how to access this. Any clues would be gratefully received.
Thu, 02/04/2015 - 21:56
Re: 460 lightswitch - rear foglight warning light, how to ...
Put the knob in the off position and give it a swift yank the bulb is under the knob
Regards
Gordon O
Sat, 04/04/2015 - 16:58
#3
Though you may have to use pliers with a bit of rag between them to pull the the knob of the switch,unless you lucky
Sat, 04/04/2015 - 22:01
#4
Only if you've got limp wrists
Thanks Gordon
