280ge oil cooler leaking
9 replies [Last post]
jhw.
jhw.'s picture
My petrol 280 is leaking from the oil cooler (coming from the cooler itself not the pipes)
Is there any pattern parts or is it possible to use an oil cooler off a different model/repair the current one?
I assume a Mercedes replacement would be eyewatering?
needamerc
needamerc's picture
Re: 280ge oil cooler leaking
MB part is BIG money. Their are aftermarket oil coolers for the T1/T2 Merc vans (? somebody confirm?) which just need the mounting brackets moved slightly.
axel
axel's picture
yes that is right eddie ,the brackets have to be altered to suit but it is the same cooler rad just the brackets are different
the biggest problem is the connections with the alloy rad fittings stripping their threads and leaving the alloy deposited inside the steel nuts so when you screw onto your nice new oil cooler you destroy the threads on that one also -nice
Oil Cooler is A123 180 02 65 £330 + VAT
MB Germany have 7
Fitted on.....
280GE / 300GD / 250GD  460 Series G's
280GE / 300GD / 250GD / 290GD / 290GDT  461 Series G's
300D / 300TD 123 Series
380SE-SEL / 500SE-SEL 126 Series
Behr Cooler
Many aftermarket options out there £150 / £180 i think
Or chance a used one
PLEASE HEED AXEL'S ADVICE ABOUT THE NUTS!!!!
needamerc
needamerc's picture
Roger that Axel!
It is virtually impossible on older engines to get the oil cooler pipes off without destroying the alloy cooler threads.
Is there a trick to cleaning out the threads on the steel oil pipe fitting?
Unless you driving it very hard or planning overland trip? Why not bypass it, until a second hand unit shows up?
cox.adrian
cox.adrian's picture
  jhw   would it be possible to post a pic on 617a whats the difference of your air box towards  the end of the Air Intake Pipe
         thanks adrian
scouse g
scouse g's picture
if you have a local high pressure hose shop, (ie pirtek) just connect your two hoses together, for the northern climate we are in you don't need your oil cooler, check out my picture for wot i did to run the engine with the oil lines connected to each other
jhw.
jhw.'s picture
http://www.ebay.co.uk/itm/MERCEDES-BENZ-T200-T300-3-0D-2-4D-1977-1989-ENGINE-OIL-COOLER-OE-QUALITY-/121418444122?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3AMercedes-Benz|Model%3AT1&hash=item1c451a6d5a
This looks around the same sort of size/fitment.
jhw.
jhw.'s picture
Thanks Axel re the threads, my mechanic was saying about that on the phone, nothings ever simple ey!
Adrian, the car is with my mechanic at the moment and I'm away, I'll get some pictures this weekend if I'm back.
Scouse, I'm in no rush for the car back so going to get it done now with one of the coolers off the vans I think!
