280GE 83' Fuse box location
Tue, 01/12/2015 - 16:22
Can someone tell me where it is located please!
Screen shots would be helpful!
Many thanks :)
Tue, 01/12/2015 - 17:54
Re: 280GE 83' Fuse box location
Assuming RHD
It's under the Drivers Wheel area below the dash / column
There is a panel that unscrews and then folds down on two wire rods to reveal the fuse board and relays etc
Oblong panel about 12" x 6" that is coloured either cream or grey like the lower dash
2 screws from memory then drops down on the wire hinges
Easy enough to do just be careful not to stretch the wiring loom etc
All the fuses (ceramic) usually need to be removed and cleaned (one by one) and also clean the fuse contact on the board itself
They hate damp and age and oxidise, a good looking (not blow) fuse is not always enough!
Fantastic
Thank you kindly
