2002 sill lights
3 replies [Last post]
brad1973
brad1973's picture
does any one have any input on why all 4 sill lights are not working ,although door switches are working ,with interior lights ?
Re: 2002 sill lights
If you are referring to the door step-sill lights; then it is usually due to poor connections (due to dampness) under the sill. These could have corroded in which case clean out or replacement is the answer.
Make sure the power is off before you tackle this cleaning as the LED light have  quite a power jolt through it.
brad1973
brad1973's picture
thank you do you think all 4 are bad connection  fuses are all good thanks
HI,
if its a G500 RHD, unless ordered as an extra, they only came with two strips for the front (driver and passenger). Be careful when you take them off, the have very weak joins/connectors that can snap. sometime a good clean will fix them up.
